Unable to send email in Thunderbird started 3 days ago
  • 4 replies
  • 2 have this problem
  • 3 views
  • Last reply by david
Thunderbird working fine 3 days ago, then bouncing back. Unable to send, able to receive emails. ISP states no problem on their end. Turned off Norton still unable to send.
Attached screenshots
All Replies (4)
Can you post a larger screenshot. I can't read it.
Best image I have
All settings are correct, SMTP in and out. Discovered needed to update Thunderbird app to .1 version. Restarted after download, same issue.
Well, there's something wrong somewhere. If you would post settings for incoming server and SMTP server, some ideas may come forth. Thank you,
